krugford
I've got an issue with my 94 Ford Escort 1.9L, as stated in the title, the cooling fan never runs. I've checked over the electrical with a fine tooth comb and cannot find a single fault anywhere. All three relays check good, I have grounds where I should, voltage where I should, and I know the fan works. I can get it to come on by disconnecting the AC pressure switch and putting a jumper on the connector to make it think the AC is running (AC doesn't actually work on this car). It'll make the fan come on low for about 10 seconds, then kick to high and stay there unitl I remove the jumper. The fan just won't run any other time.
Most of my driving is interstate/county road, so it's all 55/65 mph. The only problem is the town I pass through at the halfway point. If I get caught at more than one stoplight, the temp gauge will start to come up. When I get to work or get home and let it sit and idle, the temp gauge will creep up until it overheats (or gets close before I shut it down).
I just noticed a note in the EVTM on the pages dealing with the cooling fan circuits. It says the PCM won't turn the fan on until it reaches 230F. Is this right? That seems awfully warm to me. On the engines I work with on a daily basis, 230F (110C) is pushing the upper limit before a derate.
Am I being overly paranoid here? I've thought about wiring in my own backup switch/jumper to the AC pressure switch to force the fan on when I choose, but I'd rather fix it right (if it needs fixed) or not worry about it. I know there's a few guys around here driving Escorts, whaddya say?
