can i run a fullsize f150 transmission and transfer case
red_ranger93
ontario
i have a 302 transmission and transfer case from a full size f150 will it work wat other tranny and transfer case should i get thanks
im using a 5 speed from a 89 f150 and a np205 transfer case but i had to use a 3" body lift
I've an AOD with a BW1356 on my 5.0 Ranger. Little frame cutting and a 3 inch body lift
like he said, if you're going with a 5.0 they should bolt together but you may have to lift body/modify floorpan for clearance
do any of you have pictures of your setup just so i can look and compare its just that the transfer case looks massive for the truck thanks alot
yep, sure can. V8 swap quite common
now the only thing i have left to ask is how do i get my rad support out cause its all attached to my by weld and then welded to the cab my truck is a 93
Just drill the spot weld. Special tool could be buy to do the job too
is that wat you had to do with your truck and you never needed to put a lift in the front so the front driveshaft could clear the k member and did you use the stock motor mounts from the ranger in there original location
thanks or your time and patience lol
did i miss somthing? why do you need to pull out the rad support? I juss replaced mine and it wasnt that much fun. I used a spot weld cutter from Matco tools. It was like 80 bucks canadian and made short work of it. Im runing a 302/aod/13-56 combo in my truck with a 2" body lift and i was able to tuck everything between and above the frame rails so i can run a decent length skid plate.
my rad support is rotten the only bad thing on the whole truck so on your truck did you have to notch the frame to fit the full size transfer case and you live in lindsay so do u know of any good trails if so let me know i live 45 minutes away
thanks
the np205 fits in the frame, but i had to make it and the trans fit together.
45 min away? nice man, where ya from? I know of some nice trails around hear. Everything from higher speed 2 wheel drive fun to nasty hills rocks and mud. I had to notch my frame a bit. If ya want we can meet up and you can just take a look at what Ive done.
i live in bailieboro like 10 mins from peterboro you live in canada right lol
