Can I put a 94 2.3 into a 96 2.3
othermeans
I read that the blocks are similar but what parts would I need to swap over (if possible) to put it into a 96? Are there any modifications I would have to make to the block itself? The only reason I'm asking all this is because I got a good deal on the low miler 94 and basically just being cheap I didn't want to have to shell out money for a later model engine.
It will work but not easily.Do a search on this.has been covered
The 94 and 96 use different crankshaft sensors, they have different sensor mounts, and don't directly swap.
