Brain75
- Aug 8, 2024
- ~Sterling
- State - Country
- CO - USA
- Vehicle
- Ford Ranger
- 2.9 V6
- Tire Size
- 215/70R14
check the wiring (resistance to ground specifically) on the lead going to your sending unit... and wiggle the whole braid around a little while you are checking. I bet you have a bad ground. Intermittent stuff like that is a lot of times (usually) ground.
As far as your question, the non-ground leg ends up at the fuel gauge in the dash, the ground leg goes to ground on frame somewhere.
I forget which is which, but if it goes way past full or way below empty and sticks, you have a short or no ground. one is no resistance, the other is infinite resistance, and if you are familiar with the vehicle you will know what is past the end of the normal range easily.
