Mike1919
I have a 1993 ranger with a 4.0 and the previous owner removed the radio antenna and replaced it with an electronic one that sucks. I got a conventional antenna and couldn't figure out where to run the cable through the cowl panel into the interior so I proceeded to remove the center cover on the cowl panel under the hood. Well I dropped one of the bolts behind the engine (never did find it) and while reaching back there I noticed the camshaft position sensor isn't even plugged in. At least that's what I think it is. It goes into the back of the block or intake, and has a white rectangular connecter, about 4-7 pins. It looks like it hasn't been plugged in for a while either, I couldn't even find the pigtail for it. My question is, is it supposed to be plugged in or was it not used some years, and could it cause any problems? I have no cel and the computer only throws code 411. Also if someone could point me to where said cable enters the cab I would greatly appreciate it. Thanks guys
