Cams?
poblete
buffalo
2000 2.5l sohc, dual plugs im looking for a better cam that will give me more power does any one know off hand the model number of a cam that would work will a stock set up?
You may want to do a little more research other then someones off hand, could or could not be, info. Maybe try a camshaft specialty company?
Check the 4 cylinder forum, this question comes up alot, Mutant Pony should be able to give you some pretty good advice on the subject.
