cammo help
PaleBlue90
Solid Axle Swap
RBV's on Boost
Aurora Colorado
so after i get my ranger back on the road, im thinkin of doing cammo. i was reading in the tech section on how to do it. my question, how to i do the patterns? free hand? i feel like a retard asking that
A friend of mine did his all free hand. he took a leaves and traced them on a piece of paper cut it out and krylon spray paint and just laid the paper on and sprayed overlapping as he went.
thanks, should i unbolt the bed and slide it outta the way to i can paint behind the cab?
If you want it to look professionally then yes, It its just a wheeler then no.
Are you ever going to run it without the factory bed? How far down in between the bed and cab can you see when you look down there? I personally think those two questions would help you figure out if you want to do it.
