camber/caster eccentrics kit.
paxlineman
Paxton, Ma
ok i know that i need the kit because when i installed my lift in the front my tires are now in negative camber. my question is when i look at the kits i see so many different kinds does anyone have any good recommendations for me. also waht kind of adjustments should i get. i see some with 2 and others with 4.
The kit should have the bolt with a big egg shaped washer on the end near the head of the bolt, and a seperate egg shaped washer that slides on the other end of the bolt when installed, then the factory nut goes on.
