Cam
Rangerman87
Big Bear Lake in SoCal
'88,'11
What kind of torque numbers are possible with a colt cams equipped 2 nine,don't care about a 4.0 swap,just wonderin' if anybody has done the cam swap and was/is impressed with the results.
Hard to say since they don't offer catalog cams - they are ground with your project goals in mind, so everyone is probably a little different. Acceleration is hard to judge, but my engine was working a lot less harder on the high way at speeds of 75mph-80mph in OD. Same trans & gearing. Mid/high RPM camshaft. A lot of work for a cam change though, and some things may be required to compliment your new camshaft to make it completely worth while.
