cam syncro won't come out
white trash
Venus, PA
I'm working on a 96 4.0, and I'm trying to remove the cam syncro, I have removed the hold down clamp and have tried twisting, pulling, prying, swearing, and pounding on it and I cannot get it out. Does anyone have any ideas on how I could loosen this thing to remove it short of pulling the engine?
Thanks,
Brian
look under youtube @ ford taurus cam syncro removal. The op used a strip of metal attached to a hand weight & yanked it out-
Ok, I got it out used the youyube method, broke the plumbers tape, tried again got it.
Can anyone tell me why the shaft is 1/4" longer on a 2000 4.0 than a 96 4.0?
Because they changed design in 97.
Its 9mm, not a 1/4". They also changed from a hall effect switch to a variable reluctor at the same time.
I didn't measure the difference, the 2000 shaft does not fit into a 96 block without sawing the extra 9mm off. The differences in the sensor type where why I tried putting a 2000 syncro into a 96 block.
