cam bearing housing size
tag
1986 bronco ii
i have 2 4.0 blocks that have a #1 cam bore of 2.0725", clevit cam set says cam bore should be 2.0768" - 2.0784", when i installed the #1 bearing it had too much crush to allow cam to be installed but #2,#3 and #4 are correct. can anyone help me find the right solution?
CAMSHAFT
Application In. (mm)
Camshaft Bearing I.D.
No. 1 1.954-1.955 (49.64-49.66)
No. 2 1.939-1.940 (49.26-49.28)
No. 3 1.919-1.920 (48.75-48.77)
No. 4 1.924-1.925 (48.88-48.90)
End Play
Standard .025-.064 (.065-.165)
Service Limit .009 (.23)
Journal Runout .005 (.13)
Lobe Lift Wear Limit .005 (.13)
Oil Clearance
Standard .0010-.0026 (.025-.066)
Service Limit .006 (.15)
Valve Lift .4024 (10.220)
