caliper pins
twigboy3
washington
can i convert the caliper pins on my 94 ranger to bolts and how
You will need to get everything from a '95-'97 Ranger. You will need the parts listed below.
- Steering knuckles
- Spindles
- Rotors
- Calipers
- Brake Pads
Once you have those parts, you just swap them out. Take the old parts off your axle and install those parts.
Let me look at home, I may have everything you need minus the rotors and brake pads. If I do, I will sell them to you.
You don't need the spindles those are functionally the same.
But the other stuff? Yes.
Don't forget caliper brackets.
You also will need brakes hoses. the passenger side can come from
any 1995-97 Ranger, but the DRIVERS side hose needs to come off a 1997.
For some odd reason only the 1997's came with the two piston
brakes, but WITHOUT 4-Wheel-ABS.
AD
