Cable & vacuum routing issues . . . Please help !!!
treeguy
Shelton, WA
My bro-law lost pics that I took with his camera of my 4wd conversion :dunno: . . . on the rectangular canister that lives behind the drivers side headlight where does the smaller tube route to (the big one is easy) ?? Now for the dumb question (I took this apart back in Oct). . . where is the best place to mount the big black ground wire I can't remember if it was attached to the frame or engine :icon_confused:??? Pics would be a plus :icon_thumby: but not necessary . . . Thanks . . .
the big ground goes to the engine and make sure you have a good ground from the engine to the chassis also make sure you have all the grounds for the computer and ignition sand both surfaces with course paper for good contact on all ground wires if you have the wiring diagram it will show you all the grounds make sure they are metal to metal and tite.
The small tube goes to the fuel tank vapor line the other goes to the throttle body
