cab swap
twoll86
U.S. Military - Active
caseyville,il
ok i have a 89 b2 and was wondering what is involved in puting a ranger cab on the bronco fran i ask this because i fount a 96 2wd ranger with a rebuilt 4.0 and ne clutch an dwas think about buying it to put on the bronco 2 frame be cause i dont want to do body work on the b2 body as the roof is starting to leak
Sounds like a plan. Is is a regular cab or extended? You'll need to fab new body mounts. I'd be interested in see what you do with this. I'm going to do a body swap, and thinking of perching an extended cab ranger on the BII frame that I take the body off.
well it was a single cab but it sold yesterday is it all body mounts or just the rear ones?
To do an ext. cab swap you need to do some serious body work to make room for the rear tires, It has been done just do some searching.
im doing a standard cab
