CA: Looking for someone to talk to about BAR approved Engine change/swap process
Well I tore it down. I am very happy with what i found. Looks like someone was doing regular maintenance on this Expo because the inside was nice and clean. Standard rods, mains and bores. Unmolested. I did however snap 3 bolts on the water pump and front cover. I'm going to put new rods, mains and rings and seal everything up and get ready to yank the 4.0 out of the ranger.
That is good, I’ve slowed down in my swap, time has been very tight for me. I was trying to get the timing cover but it looks like it’s ceased on the broken bolts to the water pump ports. I’m debating taking it to someone for a total refresh, but that would cost more than I want to spend at this point. Ideally, I want to get through inspection with this motor then once I have the BAR sticker build another engine for it.
I have been really busy with other stuff. Im about 90% done with my swap. still need to have a driveshaft made and exhaust done.
Good to know. I just got approved by my smog ref yesterday to move forward with my conversion. Looking forward to more updates on your progress!
Ok. im almost done. I started my expo swapped ranger for the first time last night. Im sure the trick or treaters in my neighborhood thought what the hell is making all that noise. I was shocked when it fired right up. I still have quite a few issues that need attention. The drive shaft and exhaust being the most important. I have a question about the drive shaft. I would like to eliminate the carrier bearing and the cross member and run a one piece driveshaft but i don't know if i can. will the length be too long? If i cut the cross member out the exhaust will be much easier. Its a super cab and the one piece driveline would be about 5 inches longer than the stock two piece driveline.
I swapped to a one piece driveshaft. There should be one that fits. There are a few articles out there about it. Having one made shouldnt be astronomically expensive either.
I know it's an old thread, but I managed to get my 2001 5.0 swap Ranger SMOG certified, The California BAR checked out and passed my truck yesterday.
awesome
That is the first success story I have heard of in California. Granted most look into the process and say forget it.
Congrats! :icon_thumby:
Thanks guys, I don't have a build thread, nor do I take many photos.
All I did was to make sure everything that was on the mountaineer got swapped over and was made to work correctly.
I called the Bar for an appointment, and they gave me a checklist to follow and asked for some photos of the emission components in place, once I had completed that I called them again for a face-to-face appointment to check out the truck, it took about 90 mins to complete.
I called the Bar for an appointment, and they gave me a checklist to follow and asked for some photos of the emission components in place, once I had completed that I called them again for a face-to-face appointment to check out the truck, it took about 90 mins to complete.View attachment 113550View attachment 113551View attachment 113552
Did you have to have the Mountaineer cats, or would they accept CARB certified universal cats?
I'm not in Cali and never plan to be, but want to keep the truck 50 state legal if practical since who knows what the future holds. I do need to replace my exhaust from the headers back. Headers probably need to be done too, but Torque Monsters are on my short list to replace the OBX. Keeping cats won't be cheap, but I intend to keep the fronts at least and add rears if I ever move to a place that requires it.
Hi Guys, The mountaineer was completely stock and I ported everything over to the ranger, the exhaust was cut between the cats to move it away from areas it was touching and then welded back up..
If the cats had the Cali Carb part numbers on non OEM , I'm sure they would be accepted.
