alsalp
Hello all. I'm a new member. I'm here to research a v8 swap into my 1987 Ranger. It is a 2.3L with 5 speed, non-air, manual brakes and manual steering. I'm in CA.
I always pictured doing a Turbo Thunderbird swap but as of 2018 CA won't let me. I just talked to a CA smog ref. He did say I could put a 5.0 in as long as it is out of an Explorer. Can't be Mustang or F150. Has to be a "light duty truck" donor. He also suggested it would be easiest to stay with OBD1 like my truck. So I would be looking for a 1995 5.0 Explorer. Fortunately it's easier to find than a Turbo Coupe. I would buy a driving donor rather than crawling around the junk yard getting nickel and dimed and rolling the dice on parts. Also the 8.8 should fit too. I'm good with using the AOD. I've done 20 years of shifting that 5 speed and I have another car for that purpose.
I know the heater box needs to be dimpled to clear the valve cover but If I wanted to convert to factory A/C can I get the Evaporator case to clear?
With regards to the engine performance I'd like to be able add some internal upgrades as long as it blows clean as and looks bone stock Explorer. (CA sucks)
Anyway any relayed experience or suggestions would be great,
Thanks, Al
Thanks, Al
