C5 Transmission pan?
I've never used a torque wrench on transmission pan bolts but it certainly won't hurt. I'd guess 18-22 lb/ft for 5/16 - 18 bolt should be safe. Unless the bolts came from a hardware store.
I wanted to say one ugga dugga but for real numbers, that's the number in the back of my head too. And I've also never used a torque wrench on valve covers or oil pans. I just go back a few days later and snug up any loose ones.
So, hand tight and snug with two fingers is okay?
For context- when I first did the fluid and filter, I figured 18 ft-lb was adequate but it still bulged the bolt holes. They are the original bolts- so far as I can tell.
Like a valve cover I would just snug with a nut driver rather than a ratchet or a wrench to prevent overtightening.
Yes, I'm afraid I may have OTd by valve cover bolts as well. Leaked right away, and I was sure I was careful enough...
I think you can go a bit tighter than you normally would since you're using a lube locker gasket. Not crazy tight of course but you want the "gel" on the gasket to squish a bit and seal. It's not like a cork gasket where too tight will cause a leak.
