C105f connector pin out ?
prymetime1
Hey all, was wondering if anyone had thr circuit functions for the pins on the c105f connector on the firewall.
I was able to find the following pics online.
Any help here is appreciated.
Thanks.
Sorry. But these plugs must be one of the most highly guarded secrets by Ford.
You ain't kidding man...I cut out what I didn't need so I guess at this point I could tell u what pins are what for the basic funtions.
The problem I ran into with my own investigations of this is that the pins aren't always in the same place across the different years, and some years don't have a pinout, so it is almost impossible to do one comprehensive listing. I set out to do just that when I was researching my first 4.0 swap, thought I had it nailed, and posted my work as the "definitive answer" to this question. Then I grafted the one side onto my dash harness for the 2.9 and nothing worked. So I started over with a pair of later harnesses and repined an Explorer harness into a Ranger connector, finding it to be the most efficient way to add the wires missing from the Explorer harness. During the process, using three books I found that wires moved around and colors changed. After learning this I quickly pulled down my post intending to try and correct the mistakes later, once I had a working unit. Then mid-project my first kid was born, and I haven't had time to get back to it.
can someone give me a pinout like this for a 91 ford ranger with a 2.3L?.. ive been searching all over the web and cant find it.. its the c105f/m connector
It isn't engine specific.
ok, then where can i get a a list for each number like in the pic above where he only has a few... i would like to know what each number is for
