c-clips
Dangeranger3
Peoria, IL
Can't get it em out. Have only tried pass. side but I'm so damn frustrated after a couple hours. Any tips on this? Crosspin and gears are removed, I've pushed the axle in tons of times. The clip won't fall out and I can't push/pull it out. Someone help before I burn this heap to the ground.
you mean took the spider gears out right, try putting the 2 spiders back in place to hole the side spiders in place better than try taking th clips out
yes the spiders are removed. I got the clips out by removing the drums. It allows the axle to be slid further in (compliments of write-up not yet in tech lirary which I think the best write up)
But a new question arises. I do not have thrust washers. Is this a bad thing? And what kind of grease is acceptable for intallation? I have some brake and wheel bearing grease that is high temp. will that cause anyproblems? Instructions say "medium grease" Any help appreciated. And thank for reply Dusto
Install complete, found the thrust washers, lock rite kicks ass, thanks for reading
