gotmudd
i know that this belongs in transmission forum but i never seem to see anyone over there. my problem is that i have a 1969 C-6[ same truck as sig. and avitar]anyway up until i did body lift on truck a couple of weeks ago evrything was opperating just fine. when i lifted the cab i thought i disconnected the shift linkage,i was wrong
[ if you have to step away from project MAKE SURE you double check what you have done up to that point] anyway my lack of attention to detail resulted in me hyper-extending my shift linkage up past the park pawl
i got it to come back with a "little" force. now for the problem: when the tranny is cold it shifts like it is supposed to but after the truck is warmed up[ after 3-4 miles] it starts to slip in drive but will re-engage when shifted into 2nd. i checked the fluid it was a pint low so i topped it off with no difference. i thought at first it might be a band issue but then i thought, why would problem show up ONLY after lifting and hyper-extention of linkage? is there anything i should look for that could possibly be seen by dropping the pan/ my only other option is to drop tranny and have rebuilt, but before i spend three hours dropping it to the ground thought i would get input
