Bw1354 from a 94 put in a 00 help
OUTHOWS
Louisville, KY
I have a bw1354 t-case from a 1994 ranger and i need to put it in my 2000 ranger what kind of problems am i gona get into and can it be done? Thanks
I see no reason it shouldn't work. Biggest difference is the front output. You may be able to use the '94 driveshaft with it.
If the '94 case is electric-shift, you'll need to put a '95up shift motor on it (the one from your '00 case should work).
the 94 has what looks like a speed sensor in the t-case I think the 00 uses the ABS for speedo that wont be an isue will it. Just plug the hole and run with it is what im thinkn.
