maritimeranger
- Dec 13, 2009
hi. i got a 94 ranger, 4x4, 4.0L,front manual hubs.lever on the floor(non-elect) and standard shift
my problem started as i was driving on the road i was hearing a small grinding noise.sounded like the transmission. anyways. i check the fluids,no metal chavings and the oil was good color. so i drove it like that until sumthing breaks
now... i drive on the road then i loose any gear, 1st,3rd,4th.... folowing with the same grinding noise. even wen it is in neutral it grinds. now the funny part. the only place i can put it go it dosent grind is the 4LO on the t-case. on 2HI or 2wd it will grind or make a bang and goes forward. i can drive on the road too and feels like a trans slipping. revs then does the bang as it falls back to normal. whatever i choose the 4 LO works excelent.
would be my t-case being broken or lever bushing?
i know its the t-case as the sound comes clearly from there.
is there any body had this problem before? oh and my truck has 190000km (about 150000milles us)
