Buying new Wheels/tires, Backspacing?
Blakesgst
Hey Guys,
I would like to order some new wheels and tires this week but wanted to ask about backspacing. I plan on getting 31/10.5's (15 inch wheel) but am not sure what the backspacing should be. Also, is a 15x8 wheel acceptable for that tire size or should i get something wider? I have a 98 ranger 4x4. Any help is appreciated.
Thanks,
Blake
Ideally look for 3.75" backspace, no more than 4.0". A 15x8 rim is fine for a 31x10.50 tire, you really don't want it any wider.
i plan on running 31/10.50 on my original 15x7 wheel. 15x8 will just make them sit out wider.
Thanks for the quick reply guys.
Blake
One more thing,
I realized its only a 1/4 of an inch but which one puts the wheel out further/wider on the truck? I had planned on getting crager soft 8's, seems like i can only find them with 4 inch backspace so i hope that is ok.
Thanks,
Blake
One more thing,
Thanks,
Blake
The less backspacing you have, the more it will stick out.
Stock Ranger wheels have a backspace of at least 4" (maybe 4.5?) so a wheel with a 4" backspacing will be fine, even if it's an inch wider overall, like going from 7" to 8". I agree that 3.75 would be more ideal, but 31x10.5 tires are by no means oversized, so you won't have any issues due to backspacing either way. A 7" wide wheel and an 8" wide wheel, bot with 4" backspacing, means that the 8" will stick out an inch further to the outside.
