gertsdsbs
I'm buying this amp from crutchfield but don't know much about amps. I've read the reviews and they all love it. I have a 1986 ford ranger regular cab With a Pioneer Premiere Unit. This is my planned set up. what do you think?
The Amplifier
SPECS:
RMS Power Output (Watts x Channels) 50 x 4
Peak Power Output (Watts x Channels) N/A
Power at 2 Ohms (Watts x Channels) 75 x 4
Bridged Power (Watts x Channels) 150 x 2
Minimum Impedance Bridged 4
Minimum Impedance Unbridged 2
Best Frequency Response 20-20k Hz
THD at Rated RMS Power 1%
Signal to Noise Ratio 80 dB
Input Voltage 14.4v
The Subs: Kicker CompVT 07CVT102 and yes they are shallows
SPECS:Size 10 -inch
Impedance 2 ohms
Cone Material Injection molded poly
Surround Material Santoprene rubber
Sealed Box Volume (cubic feet) 0.8 - 3
Ported Box Volume (cubic feet) 1.25 - 1.75
Port diameter (inches) N/A
Port length (inches) N/A
Free-Air No
Dual Voice Coil No
Sensitivity 87.2 dB at 1 volt
Frequency Response 25 - 350 Hz
RMS Power Range (Watts) 50-400
Peak Power Handling (Watts) 800
Top Mount Depth (inches) 4 5/16
Bottom Mount Depth (inches) N/A
Cutout Diameter or Length (inches) 9 1/8
Vas (liters) 37.14
Fs (Hz) 32.7
Qts 0.44
Xmax (millimeters) 12.73
and heres my unit I have
Pioneer Premier DEH-P310UB
SPECS:General
Chassis Size Code IEJ
CEA-2006 Compliant Yes
RMS Power Output 14 watts
Peak Output 50 watts
RMS Power Bandwidth 20-20kHz
Preamp Outputs 4-channel
Sub Preamp Outputs No
Preamp Voltage 2.2 volts
Display Color White
Key Button Color Green
EQ Bands 3
Sound Shaping Type EEQ
THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
The Amplifier
SPECS:
Input Voltage 14.4v
SPECS:Size 10 -inch
Impedance 2 ohms
Free-Air No
Dual Voice Coil No
Vas (liters) 37.14
Fs (Hz) 32.7
Qts 0.44
SPECS:General
Display Color White
EQ Bands 3
