Buying new amp and subs what do you think?
Ok, I've had the HU in for a day and I'm REALLY glad I went that route... so far.
I read as many online reviews as I could get me hands on, and most talk about how confusing the set up of the radio is. I will say that the one knob does all thing is a little strange, but with the remote there is no need to touch the knob at all. The remote is all inclusive to radio functions so as long as you can learn the remote functions you should be alright.
Truly, I need to get my sub put in to keep from shredding the 6x8's. I didn't figure on the HU having as much power as it does. While I have dialed the bass down to compensate for the 6x8's, The highs SCREAM!!! I bought my setup from Crutchfield and the price, shipping speed/cost, and every possible item needed to install for free has made me a lifelong customer.
I hope this helps in someone's decision in buying a HU. I didn't go wrong in buying mine.
Agree, although i was going to buy the one with blue lights it didn't have the usb connection built in, in the front. Ill post picture later.
Hows this one
Sony XM-ZZR3301 1100W Max, ZR Series Class D Monoblock Amplifier
Specs:
mono subwoofer amplifier
330 watts RMS x 1 at 4 ohms (600 watts RMS x 1 at 2 ohms)
CEA-2006 compliant
Dynamic Distortion Suppressor and Active Thermal Control
variable low-pass filter (50-300 Hz)
variable bass boost (0-10 dB at 40Hz)
Class-D amplifier design
frequency response: 10-300 Hz
speaker- and preamp-level inputs
1 pair preamp outputs
fuse rating: 30A x 2
8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
14-1/8"W x 2-1/4"H x 11"D
warranty: 1 year
Ok forget the sony I found a better one. Check it out. What do you think?
Specs:
RMS Power Output (Watts x Channels) 500 x 1
Peak Power Output (Watts x Channels) 1800 x 1
Power at 2 Ohms (Watts x Channels) 900 x 1
Bridged Power (Watts x Channels) N/A
Minimum Impedance Bridged ---
Minimum Impedance Unbridged 1
Best Frequency Response 5-200Hz Hz
THD at Rated RMS Power 1%
Signal to Noise Ratio 75 dB
Input Voltage 14.4v
Features
Amplifier Class D
Low-Pass Crossover Frequency 50-200 Hz
Low-Pass Slope (dB/octave) 24 dB
High-Pass Crossover Frequency N/A
High-Pass Slope (dB/octave) NA
Bass Boost 0-18 dB
Bass Boost Frequency 40 Hz
Fan Cooled Yes
Fuse Rating 30 x 2
Speaker Level Inputs Yes
Preamp Outputs 1 pair
LED Power Indicator Yes
Width (inches) 13-11/16
Height (inches) 2-3/8
Depth (inches) 9-5/16
Parts Warranty 1 Year
Labor Warranty 1 Year
Will I need to buy a new alternator or something to juice up my truck?
yeay kenwood ur ald should be fine its a 95 amp right
I've installed that amp on 2 setups and it kicks ass. I would definitely get it.
Ben
