Busted gas tank strap
thesource
Brooklin, Ontario
My 93 SC has rear strap rotted and broke, ended rubbing brake line against frame and blowing that also.
How hard of a job to replace strap? Really don't wanna disturb gas tank also by dropping it to do this as OE fuel pump still with 200K + miles
IF you can get the bolts, it's very easy.
The pump is inside the tank; you won't disturb it if you drop the tank anymore than you would hitting a pothole. But it's not necessary if the other strap is in good shape. Just remove the skid plate, and it will be RIGHT there.
