Bushing dimensions for 2wd 2.3
Blacksmith
I have a B2300 with a bunch of old cracked/swollen/compressed bushings. The sets from prothane are very pricey ($200). Also, the ones most needed are not supplied with the kit. So with access to a metal lathe and a fab shop I figure I can make them myself without much trouble.
Does anyone know where the dimensions of bushings may be located? The only dimensions I have found are for the leaf spring/shackle bushings. I would like to machine the parts and swap them out rather than taking them off, getting a measurement, making the part, and taking the parts off a second time.
There is a Regal Plastics in the nearest town and I plan on picking up some polyurethane rod. I think I will go with 70A for hardness. From what I have read, this machines easily and is a good balance between rigidity and noise reduction.
The worst bushings on the truck are the frame-to-transmission-crossmember ones, followed by control arm, sway bar, shocks, then leaf springs.
Any help is greatly appreciated
never thought about making them out of plastic rod??? Make sure you take some pictures.
Not to sound cheezy but maybe buy stock bushings, take your measurements then return them or sell em for a discount on here?
