Burnt Intake valve
ronniepeacock
need help changed timing belt before now i cant rember what i did to ease tention and now i have a burnt valve that i need to take care of got stopped dead in my tracks ended up putting her back together just to go to work any one out there that can help
slack adjuster
Did you loosen the bolt on it? Then use a prybar to take off tension move to pass side as far as poss then retighten the bolt.:icon_idea: Hope this helps and good luck!
Basically what Chilsam said. Are you sure your issue is an intake valve? What indications do you have that a valve is the problem? I ask because there is the possibility that you have a simpler issue that could be fixed without pulling the head.
Good point!
:icon_welder:
guess that's his first and only post he probably took it to a shop come to think of it he probably traded it in on a toyota most of them don't know how to use periods either. I'm just kidding, let us know what you find peecock.
Lol!
:icon_welder:
