bumpsteer
josh-the-ranger
how do i reduce bumpsteer? i lifted my ranger 4 inches and now it rides like a turd in a punch bowl. Should i get a drop pitman arm? i got 4 inch coils and 3 1/2 inch drop brackets. can the caster get adjusted?
seems to be a common problem
yes, or build a K-link steering.
tune your TTB and build a modified K-link, and limit down travel.
yes the camber can be adjusted, get longer radius arms.
for all these things you need to contact 4x4 junkie
Get the extrem drop pitman arm from Skyjacker. I got the more expensive on the 6-8'' one. Since you only lifted yours 4'' you probably need the cheaper on the 4-6'' drop pitman arm. The 4-6'' one is about $100 cheaper than the 6-8'' one.
Yeah, you need a drop pitman arm.
A standard drop pitman arm should work adequately on a 4" lift.
