Its cold outside, and my B2 is outside. Time to daydream.... Inside, where its warm.
I know my stock frame is not going to last forever. I also know that it looks like 2 wet noodles were used as a model for its creation.
So I have decided to design a replacement frame. Something simple, that an average joe could set up, and have a qualified welder assemble. I want stock/off the shelf parts to bolt to it as well. No point designing everything when there are plenty of decent parts out there at competitive prices. I have steel available locally in 20' sticks, so material is a short drive and a shrinking wallet away.
I'm thinking 2" x 4" box steel for the main rails. What thickness should I use? I'm not a "hard-core" wheeler, so I want the lightest weight. Isn't a stock frame somewhere around 1/8" thick? Oh yeah, no tube. Benders are expensive, and its easier to bolt stuff onto a flat surface.
Stock(ish) parts i want to re-use:
-body mounts (unless i happen to have a bunch of extra mat'l left)
-my Duff coil mounts
-F250 shock mounts
-leaf spring perches
-an "outside frame mount" steering box from something.
-my Duff rear bumper/tire carrier combo
Currently I am drawing up a rough sketch, that I will post up when I get more done. When I get it where I want it, I will start applying dimensions. After that I will make a final sketch to scale.
-F250 shock mounts
