So I need to build a track bar. one of the last things I need to do to get my truck going. Anyway, I'm using the stock location on a Dana 44 Solid axle. The bolt is 3/4". So do I need to use a heim with misalignment spacers? I would need a much bigger heim if I did use the misalignment spacers. I am using a heim at the frame mount and I will be using misalignment spacers there. I will be using the same as the steering DOM...1.5" .25 wall. The reason I want to use the stock location is because right now it sticks out of the frame rail a couple inches on the outside...and if I move it from the stock location it would stick out much farther.
I guess I could use these and use the 3/4" bore misalignment spacer right?
http://www.ruffstuffspecialties.com/catalog/78x78SET.html
Thanks!
Thanks!
