iowaranger
- Jul 18, 2010
I just bought a 88 ranger 4x4 4inch lift with 31's 5 spd trans. It has a new engine. I had a buddy of mine check the timing its set at 5 with the spout out. I have to change the intake gasket this weekend because its leaking oil out the back side so i didnt have him adjust the timing. Its real doggy up hills runs great on flat land in 5 gear but as soon as i hit a slight hill i have to down shift in 4th. I knocked the cats out tonight seemed a little better. It has a new fuel pump in the tank, new fuel filter and a ton of other new parts.
When i had my 87 it ran like hell with 30's on it and i know the motor i put in it had well over 100,000 miles. Is the timing making it buck or jerk while under a pull? I have checked for vac. leaks and couldnt find any. I'm gonig to check the fuel psi what should it be?
