Bucket Seats!?
memphis19
atlanta,in
i have a 2002 standard cab and i have to crappy uncomfy vinyl 60/40 seats. what seat out out what can i put in my truck....please help!
hey if you find anything let me know im trying to do the same thing
Just guessing here, but Explorer or other Ranger seats might fit.
This has been discussed before, try using the search.
i was thinking about explorer seats but i dident know about the power seats. they hard to hook up?
Explorer Seat with Power will bolt in an EXt Cab but not a Std Cab, not to say you can’t mod the mounts but direct bolt up is not going to happen.
Ex Sport Seats are nice too but a little wider.
An of course if you can find a set of Ranger Bucket Seats then those will fit too.
The sliding tracks need to be from the type of cab the seat will go in.
Something to think about:
1) All Ford buckets (Driver and Passenger Sides) are the same seats all that is different is the tracks that bolt up underneath.
2) The Passenger Side of a 60/40 Bench is a std buckets seat.
3) The tracks will unbolt from your 200 seat.
4) If you get two JY Passenger Seats, you can unbolt the tracks for the 60/40 Seats and bolt them up to the JY Passenger Seats and end up with a set of Buckets Seats.
Usually the Passenger Seats do not have Lumbar Support or many options but it is an option to consider.
So search the JY for two sets of 60/40 Seat in Great condition and pull the 40% part and bolt um up.
AND before you ask, the Seat Pans on each seat have the exact same holes in them, so they can be flipped from side to side.
I did the 60/40 to a set of Bucket Seats from an Ext Cab Ranger in to my 2003 Std Cab EDGE and found out about the Tracks and swapping them around.
luck on the search.
