Bronco Pitman arm vs. Ranger.
Ranger44
Ford Technician
Illinois
There is a Full-size Bronco in my local yard that looks to have a 4" lift. It's steering is flat, and looks to be a standard dropped pitman arm. I looked up a few applications, and the #'s cross between some brands, but not others.
In a sense, I'm asking if that arm will work for me (3" lift), cause I can probably get it for around $25. Thanks!
Ryan
The spline on the steering box is the same if it's a '80-'96 truck.
I would suspect it's just your standard-issue drop pitman arm that drops 2" from stock, being the only other possibility is the Skyjacker "extreme" arm, which only came included in ridiculous 8" TTB lifts.
Should work OK at 3".
Yeah, I knew the steering boxes are the same, just wondered if there was a big difference that I didn't see. But after some more searching....alot more searching..... I'm coming up with the same numbers for the standard drop arms between the 2 in a few of the brands.
Thanks for the reply.
