macd7919
- Dec 1, 2009
- Automatic
Ok, this is a bit of an oddball questions but here goes....
I just converted my 2wd B2 to 4wd AND installed a M5OD, to convert to 4wd I used a transfer case from a TK transmission and bolted it up to the MDO5.
The bracket for the transfer case "shifter" that was attached to the MDO5 looks as though it was meant for a cable. I removed that, but when I went to bolt up the transfer case gear shifter bracket from my TK the bolt holes are slightly off which isn't a big deal but even if I opened them up a little to fit, the arm with the little slot on it that joins with the transfer case it seems as though it's about 2-3 inches too short. My question is:
1. Is this the wrong bracket all together? If so, should I order the bracket from a FM based vehicle or did the M5OD based vehicle come with a manual based transfer case option that I could get the bracket from?
2. Would I be better off just having this piece extended to fit?
3. Am I completely off base? If so what should I be looking for?
Thanks guys!
Thanks guys!
