Hey guys been trying to get my bronco 2 started for about a month Finally got her started just needed a new ecm relay! After decided to change out a lot of ignition part along the way! excited BUT she is doing the same thing she has done for three years now that’s it’s running. She runs for 15/20 minutes then this ticking sound gradually gets louder and the engine kind of sounds like it’s bogging when I change gears and like kind of bogging when driving in 3rd going 25 mph so the ticking gets louder (I can’t tell if the clicking/ticking sound is from the distributor) then as the ticking gets louder the oil light starts flickering and it seems to start bogging even more and smoking and just feels like something’s going to pop! any help appreciated! Here’s a summary
1. Ticking gets louder and louder gradually sounds like distributor very loud after 15 min ticking fluctuates in line with revving engine
2. Bogging sounds like how a semi truck sounds! It bogs whenever changing gears like it’s almost going to stall out but never does
3. Oil light gets brighter and brighter after 15 min and it starts really smoking from the back of the engine like looks like from valve covers thanks guys for any help oil quality and quantity good here’s what I changed in the last year and a half btw she’s been sitting for about a year I’ll do what needs to be done to fix it! But I don’t know what this issue is!
Last year and a half change/fix list
Fuel Filter
In-line fuel pump
Low pressure fuel pump
Starter
Radiator
Fuel injector o rings and cleaned injectors
Valve cover gaskets and cleaned covers
Ignition control moduel
Ignition coil
Spark plugs
Fuel pump relay
Ecm relay
Fuel Filter
In-line fuel pump
Starter
Radiator
Ignition coil
Spark plugs
Fuel pump relay
Ecm relay
