Bronco 2 stability
rangg
Hello
What I can do to get more stability in my original bronco 2 v6? I have original suspension.
thanks
Upgraded sway bars front and rear, wheel spacers, off-set wheels... All these pros also have significant cons...
Sent from my PG86100 using Tapatalk 2
define "stability"
are you worried about tipping? wanting more stability in the front-end at speed?
sultan go into marysville or bothel and go to napa all you need is upgraded sway bar bushings and napa carries them, also don't get wheel spacers those are dangerous cause they cause more stress on the wheel studs so just go get some new wheels with 4.75 back spacing and get some 10.5 wide tires and you will be set, oh also you can get new coils up front since yours is stock i bet they are wore out.
btw what color is your b2? i drive thru sultan alot and have only ever seen 2 or 3 b2's
I have never had a problem with mine and the stability. Just don't drive it like a race car and maybe replace all the bushings in the suspension.
Sent from, wait how did this get here?
Hey thanks for the input. My B2 is very stable yet better sway bars would be better! I have new front coils, Bilstein and wider wheels.
I live a few miles outside of town. There are three B2's out here. One that is like mine, a brown Eddie Bauer. Yet mine is much better shape. The third one is a non stock green. Heading west as you get into Sultan just past the gas station on the right there are 2 B2s. They are blue and red.
Thanks again!
Hi
What is the superlift traction bars? Is good to more stability?
thanks
yea i have seen the red one and blue one and then at the chevron a few months ago i saw the green one at the chevron on the monroe side of sultan.
idk about the super lift traction bars but i think they are only for a lifted truck but rangg just go get new bushings cause you don't need a whole new one
Explorer springs, and 235/75/15 tires.
