Mr X
- Jan 23, 2014
- Automatic
i have a bronco 2 axle with the code d4. its the same 3.73 ratio as my ranger. my ranger axle has bad pinion bearings and since i got the bronco axle free it will be cheaper to put that in. i know that it wont fit direct but im ok with cutting the perches off and the shock mounts and rewelding them.
my question is, the bronco axle only has 1.25 inches of offset at the pinion according to the axle specs in the tech section and the ranger has 2 inches. will this 3/4 of an inch cause problems with the gastank or will it clear.
