Bronco 2.9 Starter problems
Mine is doing the same thingstarted grinding bad on starts now it just grinds and wont trun the motor over
I had the same problem and I had to loosen the engine- trans. bolts enough to get the spacer plate loose and then align and tighten the starter bolts while the plate is loose. Then tighten the engine-trans. bolts. Also I had to take one top bolt out to get the plate to slide in easy.
Oh the plate is between the trans and the eng block...the thing that keeps you from seeing the flywheel
I had the same problem. I kept putting in remans from O'Reilly's. Junk. I bought an AC Delco Gold from Rock Auto and problem solved.
