Broken Headlights
Ryanbr6
Boise, ID
My headlights stopped working. I've checked my 4,8, and 33 fuses but they are all intact.
When i turn the key to "On" my High Beam light stays on, but i cannot get either the high or low beams to work. My parking lights go on, but nothing else.
Does anybody know what else it could be? The bulbs are fine and worked last night. Anybody know anything?
There is a short in the circuit somewhere. Sorry I could not be much more help.
i am inclined to say 'relay'... check them if you can get high, but no low, then you are having a sticking issue in the relay more the likely. pull the relay, most come apart, check the return spring and plunger/connecting disk and see if its broke/stuck.
or
go buy a new one at any parts store for like $10.
last time for me it was the headlight switch. Cleaned both switches (hi/lo beam switch too) worked ever since!
