Broken Headlight Knob Attachment
PrayingMantisJoe
I have a 94 Ranger that has a broken plastic part that holds the headlight switch to the dash. I have no idea how to really describe it other than its plastic, and the knob shaft goes through it and it helps the switch attach to the dash. I have been trying to find this part, but don't know what its called or have a part number to look it up. I was going to just buy a new switch assembly, but none I found come with this part. Any help on this would be appreciated!
Thanks
Wrecking yards are good for that stuff :)
It is called a bezel, which is used when a nut has a fancy trim attached to it
Ford generic part number is 10852, this is for many types of bezels
Because it's a 1994 Ford dealer probably can't get it.
If you do hit the wrecking yards get the whole switch, knob(shaft) and bezel, mechanical switches do break
I think explorer and Mazda B series will have the same light switches.
Thanks! So unfortunately I don't live anywhere close to a pull-a-part type of junkyard, but thanks to Ebay, I think I might have found what I need!
And you were right about that part number, it wasn't too useful...
Thanks for all the help and here's hoping a 94 Explorer bezel works!
