broke timing brlt
Cobra GT
New Orleans, La.
Hi guys,:yahoo:
New it the site, timing belt broke on the way home from work. The motor just shut off, is the 93 4cyl/2.3l an interference motor? Or do I have bent valves.:annoyed: Thanks.
since the belt broke i know i cant just rotate the motor around to line up the timing marks. do i have to take the cam loose, then rotate the motor to tdc?
4b316 is correct. you dont have to loosen or remove anything. you can turn the engine and the cam by hand to line the marks up.
