Brinker88's slow SAS build.
New bender
Nice, but, its manual!! Where's the hydraulics go? lol
SVT
Now your talking! I'm thinking about breaking down and buying a used exhaust pipe bender. It'll be some coin, but I'll be able to both bend tube for cages/sliders/beds/bumpers as well as do exhaust work. I'll most likely get square tube dies to do those as well...
SVT
Some badass Spidertrax T.R.E. tube adapters I scored from a member on Pirate.
SVT, did you want my LED tail lights now? (they aren't cracked) :D
YEP, I'll pm you...
SVT
Getting the garage ready. Here's the blocks for my frost wall. 35 each of 8x8x16 and 240 lbs of mortar. My little beater was screaming for mercy. With a 2.3L, 3.08 gears, and 32's I dont blame her :D
Tires rubbed going around turns as well...
Not much to update. Will be getting concrete in the next two weeks. Footer is poured, frost wall built, dirt leveled/compacted. Just received 3 tons of gravel for the concrete base. Will be laying down 4 mil plastic for a moisture barrier then laying the gravel on top of that. I'm looking at 4.5-5 inches of 6 bag fibercrete.
No truck updates. Again. Concrete's getting poured next weekend though :D
Oh, and I picked this up on CL for $50
screw the truck, i wanna see pics of the garage
It's 17x22. Not too bad for a small garage. It WILL fill up quickly though, I'm sure. The whole front portion is getting rebuilt as well. New beam, new wall, new garage door, and new entrance door.
Leaving everything as is but dropping back down to 3.55 gears, removing the BL, and running 31's. I'm swapping my locked 31 spline 8.8 into the new truck. I'll probably go back to stiffer TTB coils and stock steering as well.
Im stuck on what to do with mine as ill be doing the 1 tons and v8. Whether or not to keep the std cab or find a ext.. then what do i do with the 6" long arm and locked axles haha
