brake upgrade?
CreepyCrawler
NCMillwright
Wilmington, NC
it is what it is
has anyone ever taken the brakebooster,proportioning valve, etc. from an excursion and put it in a ranger? can it be done
I doubt the ranger engine could create enough vacuum to run it. maybe time for a hydro booster and 4 piston calipers
do you know who carries a good hydro booster?
I just bought the autozone 1...... you will need to make measurements to find one that will fit.... I got one from a mid 70's mercury wagon.
does this have to do with your axle swap?
if you are trying to run 1 ton axles then you want to run F350 superduty brakes and hydrobooster........ I'll see if I can find the parts list I used for my big bronco and the website I got it from .......... prolly be sunday before I get around to it.
d50 front and 10.25/or 10.5 rear will prolly be running 35-36 when i first drop them in then move up to 38.5-40s
Oh just buy some 1 ton Rockies with the pinion brake.
