Brake Rotors
AyAnthony702
So it's about time to change the rotors on my 2010 2WD XL but what has me confused is do I have to buy rotors that have the wheel lugs pressed in already? Or can I just buy regular rotors that have to be pressed onto the wheel studs?
They come as a rotor/hub combo part# 54029 you will need new bearings part #SET5 and SET2 and an oil seal part # 9150S i also recommend putting a hardware kit in for the calipers part #P833B and if you need a dust cap if you don't want to reuse the old one or if its damaged it is part #13973 all available through autozone
Sent from my E6790TM using Tapatalk
