brake reseivor removal from master cylinder
upnorthdad
hi,
Got the master cylinder off the truck... but what is the trick to remove the reseivor from the master cylinder.... is it just friction fit????
Thanks Dave
there are just some tight fitting seals on it, you have to carefully grab a prybar and just pry it out. Just be careful not to crack or break it, it can get brittle as it gets old.
