brees86
I get a rubbery, creaking type of noise when pressing the brake pedal. It sounds like it's coming from just inside the firewall, in or around the brake booster. The rubbery sound increases as the pedal is pressed farther down. Also, the problem is noticeably worse on warmer days than cool days.
I just had the brake booster replaced today and it didn't make any difference. Has anyone else experienced this? Is it likely that a faulty master cylinder would be causing this problem?
Thanks!
Keith
Thanks!
Keith
