harold
- Jan 13, 2011
- Automatic
Abs light was on previously and no abs but regular brakes worked fine. Months later I adjusted rear shoes and installed new front pads. Now brake pedal easily goes to the floor. Removed front and back lines from brake master cylinder and plugged outlets and brake pedal was hard and solid. Fuse check okay. No fluid leaks and no air. Help.
Thanks. harold
Thanks. harold
