Brake Lights Out
brian07e
Ofallon, IL
well i just found out my brakes lights dont work but the running lights do? i checked the bulbs and fuses and there all fine so where do i look next?
Check for power to and from the BOO (brake on/off) switch at the brake pedal.
well i changed the switch and still nothing. i know for a fact the lights were working last weekend. wuts next any ideas??
You changed the switch, but did you check for power?
Also check the fuses...there are two or three that control the brakes...one might be burned out...and if you don't get power at the BOO switch (sounds scary)...it's probably a fuse...
