chadwicks
- Jun 20, 2012
i have recently replaced my master cylinder (by professional).started to leak brake fluid from some mysterious place ,once inspected i found a loose compression nut on the cylinder tightened nut and proceeded to bleed brakes because had a hard pedal like air was trapped.when went to bleed brakes no flow of fluid at all.i then diconnected rear brake lines ...no fluid.then diconnected brake lines from rear distrubution block...no fluid.then i disconnected lines from master cylinder and guess what ...no fluid .can anyone tell me why and how to fix this?
